What Size Sway-Bar Bushings? | Ford Explorer Forums
Cranmaro99
2001 Explorer 5.0 AWD
I know that on 2nd Gen Explorers the sway bars had different sized bushings and mounting locations based on the drive-train of the model.
Is there info laid out anywhere stating the size bushings I'll need to replace my front and rear bushings? (Not the end links). I just need stock-like replacements.
My Explorer is a 2001 5.0 AWD 4dr Limited model, if that helps.
jusr take an adjustable wrench and put it on the bar. then measure the opening to get the diameter.
Let us know the results!
Post the results if possible
Sway bar diameter
My 2000 5.0 XLT AWD 4dr has the 34mm front sway bar.
Same here - 34mm Sway Bar on my '98 4x.
