full foot notch
- August 9, 2004
- orlando
- 92 2dr 4x4
alright, on my exploder, the front is getting a dana 60 with crossover steering, its had a D30 with modified stock steering links, and right now its on a D44 siting in the driveway
well since im going to be driving this alot, i want to veer away from using heimjoints, and would rather use stock parts that can easily be replaced if for some reason it should break on the road or at the mudpit, so all i gotta do is go down to the local autoparts store to get hte part
i also have on the truck from the last lift, the Explorer pro comp FA400 4inch drop pitman arm, and form the application chart, i see that its the same arm for the rangers/bronc2's/explorers, and then also the F100 and up to 4/99 F350's , so i was wanting to see if i could use a droplink/TRE end from one of those vehicles into a fab'd steel bar/tubing over to the crossover arm, at which i would prolly use a 1ton TRE at the steering arm on the passenger side, and i would rather not have to ream out the pitman arm to get a TRE to work
so was wondering if yall had some good suggestions using "stock" components(ie no heims)
