rabbit91
- January 25, 2011
- Surrey
- 2000 LIMITED V8 SAS 35s
2nd Generation Aftermarket Head-Unit for steering wheel controls
Hi all
Been searching for an aftermarket deck for my truck, all threads I've found are either old, don't hold the answer or the URLs don't lead anywhere.
I'm looking for one that:
- I can continue to use the steering wheel controls
- runs my stock amp
- utilizes the 6 CD changer
Threads from a few years ago said that the cd changer won't work with an aftermarket unit, if this is the case still, not a big deal.
Solution:
I was able to use my steering wheel controls and stock amp with the deck I bought. It is made to accept factory steering wheel controls but needed to be paired with a wiring kit. I did not find a way to keep the 6 cd changer but with my phone instantly synced when I start the truck and a USB stick full of music, I am not missing it at all.
Deck: http://www.crutchfield.com/S-A7tNCFt...X-BT4000P.html - Super happy with this unit, blue-tooth works flawlessly and the sound is great. A great bonus is the numerous colours which can be set to the same green dash lighting, creating a completely stock look.
Steering Wheel adapter: http://www.amazon.com/Metra-ASWC-Uni.../dp/B0039H2W66 - The kit is quite easy to install and has been working perfectly. I put a piece of electrical tape to hold the 3.5mm plug on to the back of the HU
Sub Wiring: http://www.crutchfield.com/I-rFORc11...s.html?tp=2977 - I needed to purchase this separately due to the deck not coming with it from in store. If the Deck is purchased from Crutchfield I believe it comes altogether as one unit.
Mounting: http://www.scosche.com/car-audio/product/42 - bought from Walmart but will come with the Crutchfield Kit.
Took me a few hours to complete everything; removal, wiring, mounting, final install. I suggest getting the deck from Crutchfield because it comes with everything except the steering wheel adapter plus includes a detailed package with diagrams and could really benefit during the install.
Thanks to the members who gave input before I did this, I hope this helps other members
Hi all
- runs my stock amp
Solution:
