What transmission is this model number? | Ford Explorer Forums
CPUNeck
Fort Campbell, KY
98' 4x4 XLT Rescue Squad
I thought I was suppose to have the 5R55E in my Explorer, and from what I've read I should have an 8 or 10mm bold holding the wiring connector to the solenoid pak, but mine has a clip, metal, like the ones Mercedes uses. On the nomenclature plate, on the side of the transmission was the following information:
F87Z-7000-CARM
99-285 013387 0W
Thanks
So my solenoid pak looks different than most of what I've seen the pics of here? Seems I read that you had to unscrew the plug to remove the pak. Looks like mine just protrudes through a port in the bottom of the transmission, and is connected from the side of the protrusion, not the top.:rolleyes: Just in case it matters, this Explorer was suppose to be an "ambulance prep" vehicle.
