AtTheDriveIn
- June 7, 2014
- Rhode Island
- 98 Mountaineer 5.0L AWD
So as some of know, I bought a 98 AWD Mountaineer to replace my Explorer that was totaled. I was wondering if you guys had any ideas on the following problems:
-It has some form of electrical problem - the doors don't unlock, the front dome light doesn't work and the truck continually makes the "key in ignition" beeping noise whenever I open the driver's side door. (I think the P.O. replaced the ignition lock cylinder.) I checked the fuses and they're fine. I can't seem to find the unlock relay or any relay for the dome light.
-Sometimes there's this vibration/shudder that seems to come from the rear end / differential when shifting. It's very sporadic and sometimes it happens when shifting from 2nd to 3rd and from 3rd to overdrive but never happens from going from 1st to 2nd. The shudder sounds like a worn u-joint sound but I checked the u-joints and they're fine.
Ideas/thoughts?
Ideas/thoughts?
