whats the diff. in Mandrell bent and non/stock | Ford Explorer Forums
A91EBexplorer4x4
Memphis Tn
1991 EB Explorer 4x4
i was about to do my exhaust but ran short on the $$$ . so this is what the question is, whats the difference in the mandrel bent tubing than the stock . i want to put the flowmaster 40 series muffler on there and then i guess keep my same pipe? would i notice that much diff. if i did or didnt change the pipe out?
Hey-
The mandrel-bent tubing is less restrictive. Regular "crimp-type" tubing is bent with lots of small kinks in it, which gives you a bit more backpressure than mandrel. It makes a pretty big difference in an engine blowing out a lot of air, but in the 4.0 it won't. If you change your pipe to a bigger one you won't regret it.
Luke,
well what is the size of the stock pipe? and what size do you suggest ?so i guess i should go with mandrel bent pipes and flowmaster 40 series with 2 3/4" pipe? i dont know any tips or opinions ? thanks
I'm pretty sure the stock piping is 2" from the converter back. I would run some mandrel 2.5" pipe with the flowmaster 40. I have that setup and it did give me a decent increase in power. My brother has an Explorer with the same flowmaster, but with 2.25" pipe. Mine sounds better Dead Link Removed so I give the extra 1/4" of pipe diameter the credit.
1992 Explorer Sport 2WD A4LD
The exhaust is 2 1/4" into the muffler and 2" out. The factory exhaust is already mandrel bent. The only thing is that if you are changing to an aftermarket 2 1/4" muffler, you will at the very least need to change the talipipe. If you go to a larger diameter tubing you will need to change the intermediate pipe and the tail pipe.
Paul Gagnon
Calgary, Alberta
"No Brain, No Pain"
Dead Link Removed
Technically Velveeta isn't REALLY cheese... it's a cheese food...
The stuff that other cheeses eat... I guess.
