CodePoet
- July 11, 2002
- Indianapolis, Indiana
- 1993 XLT
Ok so here's what's been happening. Earlier this week I felt the clutch not releasing all the way, and the pedal seemed alittle soft. Yesterday I went out to bleed it. I tried to start the truck....the clutch was not releasing at all the starter was turning the wheels. Anyway I pump it about 200 times and get alittle pressure, tried to drive it to Napa to get a few things but had to turn around...it was bogging down and dying. So I figure it really needs to be blead I'm following the instructions in the haynes manuel...I fill the resivor and crawl underneath to open the bleeder, I do so but nothing comes out?! I was loosening the bleeder by hand and it had the dust cap on so I know it was open and not blocked, I could also move the bleeder back and forth which I thought was weird. I know that I need a new slave cylinder...is there anything else that it could be? Should I also replace the master? Could it be a blockage of some kind? What are your thoughts??
Thanks
CP
Thanks
CP
