I got a 91 XLT. The front tires have way too much positive camber. I replaced all the balljoints and the camber bushings. The front tires camber really bad on a flat surface but when park in my drive which is an upward slant the tires go back to normal camber. Can radius arm bushing cause this ? There is nothing bent. Anybody have any ideas that would cause this ?
Positive camber is leaning out on the top of the wheel...
They camber out at the top on a regular surface and fix when the suspension decompresses(the weight pushed back by parking up an incline)
This doesnt make sense given the normal workings of a TTB suspension...
The wheels naturally camber to the negative when the suspension compresses. Its the nature of the TTB suspension. Youll notice as you lift the truck off the wheels they lean out as it goes up... Normal for your suspension. Thats why they have the camber bushings, and why they are adjustable.
It would make sense that they had a large NEG camber (wheels leaning in at top)and it fixed when parking facing up an incline...
Is this what you meant?
OK Been there, Done that, not to worry.
Sounds like there is too many degrees of NEG camber in the bushings... those bushings have several settings they can be placed in and it sounds like they are wrong.
If you put them in and adjusted them while the truck had no weight on the suspension and then set it down, this would cause this problem.
I'd say get an alignment done and if you have the right bushings now they should be able to square it away.
Another option...
find a level spot of ground
set BOTH SIDES of the truck on jack stands with the weight on the suspension (jack stands under suspension)
get a magnetic level and place it on the rotor (on a flat part)
adjust the bushings until it is as close as it can be to level.
this will get you pretty near perfect. this is how I did it with 2 Rangers a Bronco II and a Gen 1 Ex I had and it was always within tolerance on the alignment machine.
Hope this helps you
