mikeinri
- January 18, 2007
- 04 Explorer, 94 XLT (RIP)
Hey guys, I'm hearing this noise that is extremely loud but also difficult to describe (and I have no idea what to seach for)...
This is an 04 Explorer, 104,000 miles, V6, automatic.
It started about a week ago, but was very subdued in the beginning. Especially when starting from cold, I was hearing a low growling noise, especially when coasting in lower speeds. It would go away after a few seconds, and not come back for days.
Now, it has progressed over the last two days. It sounds like a screaching, scraping noise, again, especially when cold, and for at least the first few minutes of driving. Amazingly, it goes away, especially when the speed is over 40 or so.
The noise is so loud, it is rather scary to even want to drive the truck, but there are no obvious other symptoms (such as shaking, etc.).
The noise only happens when the truck is moving, and sounds like it is coming from the drivers side, rear.
I got under the truck, there are no wet spots on the ground. The very rear end of the rear drive shaft appears to be damp (some sort of oil), but not dripping. I can't find anything that looks loose or broken. Even all the CV boots and clamps appear to be solid.
I thought it might be brakes, but the noise doesn't change when the brakes are applied or released. I tried the e-brake, that works normally (holds and releases OK).
I also have lots of body bushing noises, but those have been ongoing for quite a while, so I doubt that's it.
HELP!!!
Mike
HELP!!!
Mike
