Where are you getting your 4.10 gears.. | Ford Explorer Forums
bronco loco
li new york
explorer 2003
I'm in the process to fit 265/70 on my stock 17" rims. I installed the 1.5" BL and will be installing a set of 1.5" spacers all around.
My next step is to have my differentials regeared to 4.10s from the present 3.55s, aside from the ring and pinions, I will be probably needing new carriers for the 4.10s and also master install kits.
Where have you guys purchased the gears and what exactly did you get. An itemized list will be very helful.
I'm going to have this done at a shop and Im planning to remove the differentials myself. Thanks in advance.
Summit Racing is where I plan to purchase from. But I have 3.73 currently so I just need install kits and gears.
After doing some searching, I found out that a 3.73 carrier is needed for the front, and the rear does not need a replacement carrier. I'm beginning to feel this site is self-serve;)
please keep this thread updated. I was just looking at switching my gears out to accommodate the heavier rotational mass of the 265's and compensate for the RPM drop. I was thinking 4.11s with e lockers. Its going to be a bit before I can justify the cost, but I'm very curious to see what you think about the 4.11s on a 3rd gen.
