Where is the stock amp? | Ford Explorer Forums
MattStarr
Elite Explorer<br>ECX Member
St Petersburg, FL
99' EB Expedition
I wanna get a new HU. Im reading that you have to bypass the factory amp. I have a 97 XLT with the stock bottom of the line system. NO sub, but I do have a 6-disc changer. Do I have a stock amp the rear cargo area.. I dont know!
I believe all 2nd gens have a factory amp. If you pull the panel were the little cubby is in the back of the vehicle you should see it there.
Yes its back there. I just left mine in and used an amp bypass harness to connect the two connectors going in and out of the amp. Now to really amplify my speakers :D.
RFR2212~ Ive read that that is where it is located, even if I do have it, why is it mounted way the F back there? Thanks... Is it hard to bypass when installing a new HU. B/c i want to put in the mp3/cd player by pioneer P850.... which has a fold down flap, and how would I go about hooking that up?
i wrote up how to do it
try searching for
amp bypass how
expo~ thanks man
correct i DO want to bypass the amp with an aftermarket HU, right?
--- found your thread expo..... is it really worth all that work to bypass it??
<----unexperienced installer here:D :D
If you dont bypass it you can blow it and your speakers (I speak from experience) ;)
