where to get codes pulled | Ford Explorer Forums
jared ajlouny
san jose, california
'95 XLT 4X4
ok, last night i was getting on the freeway and when i hit about 60 my check engine and od light started to flash, they flased a few times than the o/d off went away and the check engine wet away a few seconds after. i thought my transmission wwas going out so i tested to see if the od was working, it was. i was wondering where i can get my codes read, i tried kragens,a nd ford wants 160?!!??!?! anyone know
Not sure if Autozone still does it for free or not but you can try them.
1995 Explorers are OBD I, Autozone won't run OBD I codes.
You can buy an OBD I code reader at WalMart for around $25.
they are only 25 bucks? i thought these thinngs were like 400 bucks?!?!
code readers to read EEc-IV or ODB-I are very inexpensive..
Code readers to read ODB-II are 100+
Scanners to read ODB-II can be $400+ (my neighbors snap on model cost him $5k)
Scanners can get real time data (what is happening now, e.g. current rpm, o2 sensor voltage, TPS voltage etc) when a code reader just gets the codes that are stored..
~Mark
some tuners also read codes... a thing to keep in mind so you don't buy two tools that can do the same thing...
Call Autozone. Maybe Kragens. Make a few calls and you might get lucky. Worth $160.
Kragens (Checker) will rent an ODB-ii scanner, but I don't know if it does ODB-I (EEC-IV)...
its one of those, pay for it rentals.. (e.g. give them $300, they give you the scanner, you give back the scanner, they give you $300)
~Mark
So does he have the same ECU as a '94? If so he can get one from walmart for about $25.
Yep, although I think they are closer to $30-$35.
edit: some AutoZones will run EEC-IV codes, but not all of them. If you don't want to buy one, call around and see if any local AZs do it.
edit #2: $15 Reader
