where to get it????? "lift" | Ford Explorer Forums
chrisw2012
tn
2003 sports trac
i have a 2003 2wd sport trac manual tranmsission. i have been looking for a 3in body lift and have had no luck. can ANYONE tell me where i can get one or give me a link to a site with the best available. im not wanting a suspension NOR am i wanting to do i torsion swist i am simply wwanting a 3 in body lift. and sorry to sound rude but for the ppl thats going to ask why do you want to lift a 2wd the answe is simply because i want to:) so if any one has any links or can point me in the right way thanks in advance
im not 100 on this being that i have a 2WD ST with a suspension lift, but i think you might need to look into body lift kits for rangers. i hope someone else can specify. good luck
Have you searched for the Performance Accessories PA883 kit?
no i will look into it thought finally decided to get one and now that i want one cant hardly find 1
The only ghing you'll need for your 2WD 5speed as far as body lift extras is to get the shifter extension, everything else for the truck is included in the kit (if it's 2wd or 4wd doesn't matter). Hell, making an extension would be easy. Just saying. Performance Accessories have the extension so you'd really just need to call them or tell whoever you're gonna order the bodylift from to add that on.
Wouldnt it be the same part number as all other ST's plus the shift extension? PA70023 is the number for the ST kit.
well i just checked with them and they said that was only for a 2001-2002 is true or do these people just know what to read off of a piece of paper??? it says it will fit 01-02 models but not a 03 so just tryin to make sure it will work before i spend the money
Yup 01-05 kit is the same.
The kit works for all 1st Gen ST's (4wd or 2wd) (2001-2005) just listed as '01-02. You'd think they would update the model years.
