Which fuse controls the fog lights on a 2003 Sport Trac? | Ford Explorer Forums
marriott1
Norman
my daughter broke the lens off one of the lights embedded in the front bumper and neither are lighting up now. I wonder if it popped a fuse? I am going to purchase another fog light tomorrow. Valeo gf 30 fog lamp. I want to check the fuse in panel but do not know what number controls the fog lamps. Anyone have a manual that could check for me?
Welcome to the forums!!
You know the fogs do not work if the multifunction switch is in the "high beam" position, right? All of the head lights work, low/high? If so, fuse F1.29 is the power for the fog lamp relay.
2003 Sport Trac Owners Manual
The fuse diagrams begin on page 138. Look at fuse 29 in the under hood fuse box, diagram on page 142.
Thank you Steve - I will test the high beams and then try fuse 29
Hello Steve - thank you for the tip on Fuse F1.29 under the hood. It is a 15amp fuse and I changed it when I installed the new fog lamp on the driver side. Both High beam and low beams work but the fog lamps did not light up. Perhaps the bulb on the passenger side burned out when the driver side fog light lens broke? Joe
was the fuse broken/blown?
try swapping the relay (relay info is in the owners manual also), swap with a like one in the fuse box.
lastly check to see if the fog light switch is turned on.
Thank you Steve - the lights work after changing the fuse
:thumbsup::thumbsup::thumbsup:
