which spark plugs | Ford Explorer Forums
which spark plugs
SenseiJ
West Coast
2000 Mounty 5.0 AWD
2000 mounty 5.0 gt40p heads...
I got Motorcraft finewire platinums
P/n sp-432
I've read the motors prefer copper?
Did I make a mistake?
What are yall runnin?
come on guys?
20 something views and no one has input?
Those plugs are fine. Autolite platinum are good as well. Just use the stock part numbers is all. Can't go wrong with either of those for stock or slightly modified.
Are you tuned and have a bunch of high HP performance mods, needing special plugs and wires?
well eventually i feel i'll need to switch to some performance plugs with a certain heat range/gap.
I've got a parts list i'm about to double check and order everything.
heads, cam, rockers, 1" phenolic spacer, i'll build a full exhaust, intake has been modified to receive the coldest and freshest air possible. 30lb injectors, upgraded in tank pump, maf calibrated for injectors
Also getting an sct x4 and a tune for 91
I recommend don lasota
