Which TC's bolt-up to the 302 V8? | Ford Explorer Forums
soloist3
Phoenix, AZ
'97 Mountaineer 5.0V8 AWD
So, I am looking for a new transfer case, looking to get away from the BW4404 into something that is either manually operated or electrically automated (if it's reliable). Which cases will bolt up? I keep hearing things about the BW1354; which one's are both very reliable and will bolt to the 302 V8 without any custom fabrication needed.
I recommend an Atlas 2 or 4speed. If you don't want to spend that much, the 4406 swap is great. Run a search on the forum and you can read all about it. The only thing I ran into when I was doing my 4406 swap was that I could only find expedition driveshafts in NC with either a 1410 front u-joint or a 1350 CV. The CV section was too long for the 1350 shaft and the 1410 I had to dent in my gas tank to make it fit without hitting.
