Which Tranny????? | Ford Explorer Forums
Which Tranny?????
aiiraciing
OC
04 Ford Sport Trac
Im trying to figure out which tranny I have in the 04 Sport Trac?
The reason is that I need to figure out if the Mustang or any other share the same tranny so that I can find a Gate Shifter for the ST since no companies show the ST on there parts list.
Thanks, Brian
In 2004:
The available transmissions are:
D — Five-speed automatic overdrive, A5LDE-NR/5R44/55E
How do I go about figuring out which 1 came in mine
I bought it used so I don't have a manual
Or am I misunderstanding your post
Thanks
The trans code "D" is the only code for 2004. The A5LDE-NR/5R44/55E is all the same transmission as I see it. It's basically an old A4LD that has an extra gear and is electronically controlled. Someone correct me if I'm wrong. Other than Explorers and Rangers I don't know what you'll find this transmission in.
