While driving the 4Hi and 4Low blinks. | Page 2 | Ford Explorer Forums
captTelescope said:
Jefe, you remember correctly. I had to remove the shift motor to get at the front sensor. I'm in the middle of this, and have to replace a sensor I broke the flange off of :( . ($40 penalty for clumsiness) How do you pop out the pins?
i just replaced the shift motor...you take a pair of needle nose pliers and pull out the red thing in the connector and then you take a very small flat blade screw driver and push the plastic piece next to each pin while pulling on the wire...it shouldnt require much force AT ALL and should easily slide out(these hold the pins in and the red thingie puts pressure on them so the pins dont fall out) i know your prolly already done wokin on this but just in case ;)
Thanks, r37rebution. Better late than never. Another important step is to make a note of which wire goes where. :rolleyes:
I figured it out how to get them out all by myself, and got so excited that I popped all three pins before I remembered I had to put the new ones back in the right holes. Lucky me, got it right on the first guess.
