hazmat456
- May 27, 2007
- tomah wi
- 1997 mercury mountaineer
my hitch is rated for 10,000/1000 with a 2" receiver pulled my 6000lbs camper just fine w/weight distribution.I have pulled many vehicles and loads with a tandem car trailer without any weight dist.just be careful how you load, center your weight over the front trailer axle and that should give you the ten to fifteen percent on the hitch your looking for, make sure that you strap your car down by either the tires or the axle not the frame let the towed cars suspension work otherwise the car could shift over bumps, or even worse you could break a chain or strap when it dose bounce. Ive seen it happen with a logging chain holding a full size truck by the frame, broke the chain and the truck came right off the side of the trailer.
