meyek91974
- August 21, 2008
- Louisville, Kentucky - Let me no f u r nearby
- '99 Explorer 2wd Edd.B
I had a 97 4door 4wd that I put 31x10.5s and I got around 12mpg and now on my 99 EB I put LT235/85R16s to have a bigger/taller tire and my center console tells me Im getting 28-31mpg when Im on the highway.
Is it because they air up to 85psi (I usu go about 75psi)? because they're about 3/4 inch narrower? cause the tread is linear? They're tires from an electrician's box work truck Or ???? combination of all
I know when I have them aired up & I put it in N I can push it with my thumb once I give it the initial push.... but rpms & gear ratios would still make the engine run the same RIGHT???
