Lazzman
- June 27, 2005
- Massachusetts
- 1998 Sport 4wd- V6 Sohc
My 1998 V6 SOHC explorer bogs out on hot or humid days. Mostly humid I would say, as I have had problems with it in 70 degree weather. I first noticed this problem when I swiss cheesed the air intake. I did this over the summer and it seemed to bog on humid or hot summer days. Ran good with none of these problems before I did this.
My bad is that I used to oil the K&N Filter from both sides with lots of oil. I am thinking the extra air flow might have dislogged oil on the top of the filter and splatted it on the MAF sensors. I did notice the MAF sensors where black with something. I sprayed and sprayed the sensors with Radio Shack electronics cleaner and let it dry. Seemed to make things a bit better, but still not great. I would say on muggy humid days that the gas milage is about 10 mpg or less when under throttle because of the bog. Yes, its that bad.
My questions is if the MAF Sensors are in bad shape would they cause this type of problem? The truck runs real strong in the cool dry weather giving it two personalities. I am not getting a check engine light either. If the MAF Sensors are dirty and the radio shack stuff will not get the oil off- what are my options?
Thanks and sorry for the long thread.
p.s. anyone messing around with and aftermarket air cleaner should read the instructions thorughly and not oil the thing from the inner side. If the filer is round this won't be a problem but mine was flat.
