- February 2, 2002
- 1998 Mountaineer AWD
I’m talking purely of power output. More power you squeeze out of an engine, by any means, adds wear to the entire rotating unit.On older vehicles designed for 87, then yes. But if the vehicle is designed to run with 89 or even 91 octane it will adjust timing accordingly, you could even start knocking if you ran too low of an octane for the engine (though I think most manufacturers account for that). However it will take a while for the computer to re-adjust to a new octane so it may take 2 or 3 fill-ups before you notice a difference.
My Ram was rated for 89 but could do 87. Only time I ran 89 was if I was towing and there was a power difference and it was also not rated for E85.
As a way overblown example, you could squeeze 500hp out of one of these. Or it could be tuned to run 250hp. The 500hp motor would have a drastically reduced lifespan.
