porter72
- December 7, 2009
- Gardiner,Me
- 2004 XLT
I am not sure if anyone can help. I have an 2004 Explorer v8. I do not have the money to have a dealership look at it. I am not sure where the noise is coming from, front or back. It is kind of feels like a shuttering when you step on the gas from a stop. There is a slight grinding noise when it happens. The grinding is not bad enough that it makes you cringe but, its there. I know my front drivers side lower ball joint is bad and have an appointment to have this fixed. Not sure, but, this does not feel like a ball joint. Also, I had the oil changed and they said i should have the differentail fluid changed. I have been holding off because the fluid I need is so expensive. Maybe this is the problem??? Thanks for your help.....Chris
