Will it work? | Ford Explorer Forums
Will it work?
stoogesrule
MD
1991 2 door eddie
Hi, I took my stock radio w/ cassette outta my 91 eddie. I found a radio w/ cd that was in either a 92 or 93 eddie that was in junk yard. Its a sony(produced for ford) F17F-18C815-AC...Will it work? Do I need a special harness? Was it locked when I removed it? I plugged it into the same jacks in the 91 and nothing. Did I get beat? Any info...thanks
It might have the same plug but the wires are probably a little different.
theres more to it
Hi, In my 91 that I am trying to get cd radio to work..The plugs are the same number and everything but mine has a amp near the back window and the 93 that I took the cd player outta of did not. Could this be causing the problem? I didnt even know I had a amp. Is there a way to get this cd player working? thanks
Yep. You have to run through the amp or bypass it. Have fun.
Ford CDR in place of PAC Cassette
The CDR you mention requires an amp (the truck you took it out of, should have had one, too). If the radio you took out of your truck was a Premium Cassette model (with a -19B165- base part number), it SHOULD have worked.
Couple things to try. In the upper RH corner of the connector block on the back of the radio, there is a small almost square plug (six pins) - some radios back then need to have a "bypass" connector in this location. If your old radio has one, and the new one does not, try plugging the small bypass connector from the old radio into the new one (if the radio needs this plug, but does not have it, it will power up, but there will be no sound out of the speakers).
Another thing to try - the amp in your '91 requires a 12V turn-on signal. Later Explorers used a 5V turn-on signal. If your new radio is only putting out 5V on the amp turn-on circuit, it will not fire up the amplifier. You can by-pass this by swapping the amp turn-on wire (pin #8 on power connector) to the "power antenna" lead (pin #4 on the power connector) on the radio (it's a 12V source, and not used in early Explorers).
If none of those work, then, the unit may have been bad when you bought it.
regards,
Jeff
