Will the AWD T-Case bolt up to a F-150 Trans?? | Ford Explorer Forums
DieselHilux
95 ford contour
I plan on swapping a 5-speed from a F-150 into my explorer and was wondering if the AWD T-case will bolt up to the Trans???
I'm not for sure but I think it would as long as you get one that has the BW-4406. If I were you I would just keep the BW-4406 so you can select if you want 4wd or not.
X2 on keeping BW-4406
If the F-150 transmission is from a 4WD, then YES, the AWD BW 4404 will swap right in...just as easily as the BW4406 that comes attached to the tranny....
Ryan
