- March 16, 2013
- Woodstock, GA
- 04 Ford Explorer 4.6l
Left rear quarter panel, below D pillar. Tail light to left.
You can see the faster I plan to use and the hole. Fastner is currently offset from the hole. Of course I'll remove the paint first, just wanted to know if it would be sufficient. This will make the ground wire about 10 inches.
If it helps, I don't mind running two grounds. One to the common seat mount screw.
Amp is a Kicker DX250.1, so it's not like it's a big amp.
Holding off installation until I hear info on this.
