1lowlude
- May 2, 2022
- Brampton
- 2018 Explorer XLT
Hey guys, I'm throwing up o2 sensor light and it's only because the o2 sensor got damaged I don't want to get into that story because that's another story on its own but anyways so I got damaged a little bit so it's throwing the o2 sensor code anyways I have an o2 sensor that is almost identical and the only difference is one letter in the part number so I don't know if someone here has more knowledge on what I want to do if it will work or not but I will show you the part number and hopefully somebody can make sense of it because I've tried looking online I can't find nothin
O2 sensor currently installed is factory Ford motor company and the part number is as follows FL3A-9G444-AA
So the o2 sensor I have that I want to replace with hoping it will work is again Ford motor company factory OEM and from what I found is for a 2018 5 l Mustang and it's part number is as follows FR3A-9G444-AA
So the only difference in the part numbers is the letter so I don't know what that means or what it will do what it won't do all I want to know is can I put it in and will it work fine and give it to my engine light?
Thank you so much and hopefully I get a response relatively soon because I'm just sitting in the parking lot researching and waiting for a response thank you
