Window won't go up | Ford Explorer Forums
Window won't go up
spence7607
El Paso, TX
94 XLT
I have a 94 XLT 4wd and My drivers window will not go up. I search on here and all my symptom lead me to the window motor bushings. Checked those out and the bushings were fine. I opened the motor and it was burned on the inside, so I installed a new motor. It worked fine for about 2 days, and this afternoon when I got home from work the window will once again not go up. There is power at the switch, and I know the motor is good since I just put it in on Saturday. Anyone have this problem before, or have any ideas what it could be?
maybe the cables that help pull up or the "window track" is off track or messed up?
