Windshield Washer motor | Ford Explorer Forums
Tony H
New York, Wading River (that's on Long Island)
'91 Eddie Bauer
I haven't dug into it yet. Saturdays job.
Does this motor pop out, unscrew out or what. It's not working. I will electrically buz my way down to it but If it gets power to the pump , I'm guess, hoping I can pull it apart and get it to fire up.
Any suggestions will be helpful.
After taking off the rear plastic panel, you then pull off the thin plastic layer. There are 3 bolts to remove to get the motor loose (make sure to take off the wiper arm). Then you just have to mess with it until you can get the motor out of the door panel. Not hard at all after you get past the plastic panel clips.
Mis understood
I was talking about the Front Wiper Washer motor / pump.
My bad...
Sorry about that, I seemed to miss that detail :p
I've never done the front wipers so someone else is going to have to chime in.
cake man.
The resevour bolts in but the pump itself just snaps into the resevour.
It is easy acess all in all.
Easy fix. Had 12V at the connector so I Pulled the Tank, pulled the motor. Put 12V on the motor and it spun. Jerky me, I should have just tried cleaning the connections first.
Just a crappy connection.
Well, now I know how to diassemble it if I have to.
