wiring diagrams | Ford Explorer Forums
wiring diagrams
jamessmithii
dc, washington
2007 sport trac
im looking for the fog light wiring diagram. does anyone know where i can get my hands on a copy? i dont want the complet manual just the wiring for the fog lights.
My wiring manual is at work. I'll try to remember to scan that page tomorrow.
We appreciate the effort AndyInFlorida!
thanks Andyinflordia.
i think its stupid to have to buy the complete wiring manual for $60 from ford. all i need is just that one diagram. i bought my sport trac as a shell thinking i could add the accessories in as i go. found out that if i dont buy it with it, ill probably wont be able to get it. fortunally i found a place that is working with me to get the parts.:exp:
My scanner is on crack, but I'm looking at the diagram. Is there any particular piece of info you need that I could just tell you?
see what happen was, i gotten the 2007 sport trac with outh the fog lights. thinking that i could put them in later (usually ford per wires the vehicles for most every thing the have for accessories). after searching for awhile, i finally found the fog lights. the only problem i have is that now the sport trac isnt wired for the fog lamps. ill have to creat a complete wiring harness for the fog lamp assembly. i want to thank you tho for at least replying and trying to get it for me. its winter right now and im not in to much of a hurry to get it wired up. maybe later i can find it.
Well, welcome to the site. Did the lights come with wiring at all?
Actually, making a harness for them isn't bad at all. Run one pin on each bulb to ground. Run the other two together to a single positive wire. Run it to a relay. Add a switch. All done! (3rd diagram) http://www.suvlights.com/information.php?info_id=25
I think some parts stores even sell the harnesses already made for aftermarket lights. All you'd have to do is crimp in a couple of these: http://www.suvlights.com/product_info.php?products_id=215 (Get the ones for a 9005. They'll fit the 9145 bulb.)
