frankcal
- March 9, 2010
- Perris, California
- 03 Sport XLT 3.73C, 5R55E
So I bought some lights off of ebay for real cheap with the plans of "upgrading" my back up lights. My original plan was to hook up the lights by splicing into the back up lights power source, but decided against that because I wouldn't want them on everytime I back up only when I really need them in the dark, mostly backing out of mine and my parents driveways because there is a lot of obstacles.
http://www.ebay.com/itm/2x-9W-LED-D...r_Truck_Parts_Accessories&hash=item4d1523b7a3
Those are the lights I bought off of ebay, right now I got two just to test them out and see if they really worked and plan on buying two more. Got them today and they are really bright so I will be moving ahead with my plan and am buying the other two.
My plan is to mount them on my bumper, basically in the same configuration of explorers have the back up sensors. So this is where I have questions now, with the wiring. I understand the basics of it because I installed 3 hid lights up front. I just want to be safe with them and nut ruin or blow anything. The wires on the lights are really thin, best way to compare would be light #5 led on a mechanical pencil. I am going to run all four wire to one switch on the radio bezel and ground them to where they are going to be bolted on.
Basically what gauge wire would I want to use to run the power from the battery to switch, and from the switch to the actual lights. And what size fuze would i need on it.
Also I want to know if what i have planned is even right to do, which is wiring up 4 lights to one switch and relay. I read up a bit on them and everyone says to only run 2 of them, but I don't think it'll be an issue because each light is only 9watts for a total of 36w which is still less then most of others single lights. Also if anyone has any tips as far as install goes i would really appreciate them. I plan to run the wire through the rear bumper, through the cargo area under the carpet all along the side of the driver side to the back of the stereo, then from the stereo to the battery. Kinda worried about drilling through the bumper, mainly if it'll be fairly easy to do.
Sorry for the very long (essay) type of post but just want to be thorough and give the most info I can give to get the best possible answer and not waste too much time. Thank you in advance for any help or tips. Also any criticism would be nice, just to know if its a dumb idea or if there's anything in my plan that needs fixing.
