Detfruit
- August 3, 2020
- Raleigh
- 2014 PIU
Hello everyone, I recently bought a 2014 PIU and have learned alot from this forum already. I've bought and installed a hitch, started a wrap, OBD cable on the way, and 3d printed the bins for the select shifter and traction dial.
I pulled and put in a floor console from a 2013 Limited which has a 110v outlet in the back, and the front media hub has both USB's and the RCA din. I'd like to replace that with a aux/usb input. I'd also like to wire in the 110v but I'm not sure if the inverter is located in the floor console or up in the dash? I've seen the kit for wiring in Aux for the PIU and am going to use forscan to activate the AUX and maybe mess around with other stuff as I learn, but what wires should I be looking for to connect the AUX and enable the USB's for charging as well as connecting the 110v inverter?
Last thing, how do I identify if/what version of sync I have? Im planning to post pics once I'm back home at the end of the week. I'm really looking forward to learning lots more from this forum and seeing others rides!
