barneyhyphen
- February 11, 2008
- Nashville, Tn
- 1999 Explorer EB 4.0 SOHC
2000 4.0 SOHC Explorer XLT 190,000 miles. CEL on.
In the morning, when cold, the car will start and immediately climb to approx 1,600-2,000 rpm. It will then immediately drop back to 200-300 and die. start it again and same thing happens.
The only way I have fornd to combat the problem is to rev to 2,500 rpm, pull quickly in to "D" and attempt to pull away. If I can drive for 2-3 minutes without having to come to a stop, the car will then behave fine. put new plugs in two weeks ago which has made NO difference to the cold start problem.
Took the car to Autozone a month ago to have the codes pulled and they came up with 0171 0174 (I believe).
I'm pretty capable with doing just about anything that might need to be done. Any advice or help would be most apprecaited. Thanks.
