Would like opinions and experiences with these.... | Ford Explorer Forums
ton_e_montana
North Central FL
2002 Explorer Sport
My friend just got them on his ex and likes them, only they are slotted not cross drilled. I heard the the ones that have holes drilled in them are most likely to develope cracks and can cause the rotor to shatter.
Ok yeah, that's like 5% of all rotors ever made, and it's a rumor to an extent. That's the same jibberish that scares everyone away from them.
Tony, make sure they're zinc coated or something, or else they WILL rust, badly.
I called this company, they seemed pretty reputable. But their "60 day warranty" is what I'm afraid of. If they crack, it will be beyond that.
Thank you for the responses. Do you still have your connection for the ones you run draft? (with coating)
