11b4v
- May 31, 2001
- Atlanta, Ga.
- 94 XLT
Hello
My first set of lights are wired per instructions with the power lead directly off the battery.
What I'd like to know is when adding more lights, can I just keep attaching the power lead to the battery?, or is there a safe alternative than to just adding wires to the battery terminal?
The second set will be mounted on the roof rack, and I plan to use the relay and not take any shortcuts.
I am also planning to run both the ground and power lead along the rack, down/inside the rear hatch jamb, ground to frame, and extend the power lead under the vehicle to the battery/relay/switch.
Will I run into any problems extending the wire in regards to delivering current?
Thanks all in advance for your help, mv
