yellow flashing warning light | Ford Explorer Forums
martin431
Gloucestershire
Explorer 1997 petrol /lpg
Morning all...
just taken car on good run to Brittany ....
have a flashing warning light (d)
cannot find any reference to this online ....??
Any help and advice appreciated
martin
Is it the overdrive light in the bottom right of the dash? That'd indicate a problem with the gearbox.
If it has the shape of an engine in profile then it is the "Check engine warning light".
You need to have the system checked with a OBDII scanner then post the codes here to get further info on what the possible problem is. Although the place you get it scanned may be able to tell you what the codes mean.
Plus as you have recently been on long journey you should check; coolant level, brake fluid level.
Thanks..
All seems to be running fine ..but.....will have a good look bit later
Just been out and seems to have disappeared
I have a fault code scanner ...will check and post...
Just an update....
I had gearbox oil and filter changed and no light since .....result
