Navock Matt
- March 10, 2022
- Longbeach
- 1993 ford exploer sport 4
I have 1993 ford explorer sport 4.0 went to have smog check failed they said 02 sensors are bad . I know a lot of people fail smog and they put new sensors on and fail again, so i removed them bench tested both of them with a torch and they passed the resistor test, checked my haynes repair book. started with the power connection checked the Lt blue orange wire there was no voltage going to 02 sensors , the book says check fuse18 15 amp. went distribution box found no fuses bad. so i removed fuse box turned it over so i could see wires to fuses, found no Lt blue orange wire at box so i went to pcm found the wire there , so i tested wire to 02 connector no continuity so i installed another wire from pcm to a connecter before 02 sensor, now i had continuity but with key on no voltage at all.I checked again and again no power three days trying to figure out problem. Then i tried starting the car it would not start, so went to tank to listen to pump to come on heard nothing so i figured pump was bad dropped tank checked pump with another battery and pump came on, Now im thinking great now 2 places no voltage, every thing else seems fine. So what do you think bad PCM, one other note book says there is a fuel pump fuse at distribution box there is no fuse all fuses are good evan the ones under steering wheel. PLEASE HELP ME
