- October 12, 1999
- Pennsylvania
- 2024 F-150 Tremor
http://www.zainostore.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=Z-PC
Introducing Zaino Fusion - Dual Action Paint Cleaner Swirl Remover
• Eliminate common paint defects quickly and easily!
• 100% compatibility with all painted surfaces and Zaino paint products!
• Water-based formula means no mess, no staining, and easy clean up!
• Features the world's first true self-dissolving, fused tri-particulate, diminishing abrasive system
• No fillers or oils
• VOC compliant
• Perfect your paint with Zaino Z-PC Fusion
For years, visual imperfections such as swirl marks, scuffs, scratches and buffer holograms were the scourge of perfectionists everywhere. They infected vehicles without any discrimination - show cars, daily drivers, imports, domestics and custom vehicles all suffered. But worry no more - Zaino, the world's leader in paint care technology, has the antidote for all of your paint ailments: Zaino Fusion Dual Action Paint Cleaner Swirl Remover ("Z-PC").
Featuring the world's first (and only) true, self-dissolving, fused tri-particulate, diminishing abrasive system, Zaino Z-PC Zusion is just what the paint doctor ordered for your vehicle. Whether your paint is suffering from spider-webbing, minor scuffmarks, or a fully developed case of the swirls, Zaino Z-PC Fusion has the cure. And best of all, it works equally well when used by hand or machine, making it as versatile as it is effective!
Thanks to Zaino's advanced, fused tri-particulate, self-dissolving diminishing abrasive system, swirls and other defects are safely removed from your vehicle's paint. The ultra-intelligent abrasives gently and carefully knockdown high spots on your car to reveal an extremely smooth, super-reflective, mile-deep shine. Swirl marks and other blemishes will literally disappear before your eyes, and they'll stay away - Zaino Z-PC Fusion contains no fillers or oils.
With Zaino Z-PC Fusion, you'll be amazed by how deep, glossy, clean, and blemish-free your paint looks, and you'll love the compatibility that it provides. Unlike other paint prep products that are typically loaded with cheap oils and fillers, the water-based formula of Zaino Z-PC Fusion requires no washing afterward - just apply and remove Zaino Z-PC Fusion and go straight to applying your favorite Zaino protectant. Further, there's virtually no effort required to apply and remove Zaino Z-PC Fusion. Just wipe it on, work it in (either by hand or machine) and wipe it off.
Zaino Z-PC Fusion is perfect for any type of paint - from single-stage paints to clear-coated finishes to gel-coats, Zaino Z-PC Fusion will bring out the best in your paint. Metallics will sparkle! Pearls will pop! Reds will scream, "Pull me over," and your black paint will never have looked so smooth. It's perfect for domestic cars, European cars and imports. So whether you're driving a super-exotic performance car or just running the kids around town, be confident that no other paint cleaner is as advanced, effective and easy to use as Zaino Z-PC Fusion is.
So say good-bye to swirl marks, scuffs, spider-webbing, and other annoying paint defects. Zaino Z-PC Fusion takes your paint to a whole new level - one that's certain to drive other enthusiasts insane with jealousy!
The Z-PC bottle contains 8 fl. ozs. (236 ml.)
$12.95
My only question is since most polishing systems have an abrasive, light, and gloss polish, how will this work? Does it just depend on the pad I use or is this an idiot-proof light polish?
I'll report once I try it.
• VOC compliant
$12.95
