- September 1, 2002
- Lake View Terrace, CA
- '91 Navajo '99 X '19 Rngr
Anybody ever use there stuff? I've been looking at the Evolution Programer. It's about $400 bucks but I heard some say a increse of 3mpg
That's pretty impressive
Plus you can control and monitor just about anything in the drivetrain
and it matches the inside of the truck
KEY FEATURES
• Gains of up to 35 HP and 50 Ft Torque
• Sleek Design Stays with the Vehicle as a State-of-the-Art Display
• Programs in minutes
• Ships with a Custom Designed Mounting Pod
• USB Updateable over the Internet
• Change Speed, Rev Limiters, Adjust Tire Size and Gear Ratio
• Display and Clear DTC Codes
• Improved Fuel Economy*
• Adjustable Color Screen
Your Evolution monitor allows you to monitor the performance of your engine’s vital engine components and output values. The following parameters can be displayed on the main Evolution screen (maximum 4 at one time):
• RPM
• MPH
• Engine Coolant Temp
• Engine Oil Temp
• Transmission Fluid Temp
• Cylinder Head Temp
• Air Intake Temp
• Line Pressure Control Desired
• Fuel Rail Pressure
• Output Shaft Speed
• Turbine Shaft Speed
• Manifold Air Flow
• Manifold Air Flow Sensor Voltage
• Variable Cam Timing Actual Advance
• Spark Advance
• Torque fuel/spark Limiting Status
• Fuel Economy
• Engine Load
• Accelerator Pedal Position
• Battery Voltage
That Evolution can sound an alert when certain engine parameter levels are met. The following alerts are available:
• Spark
• Engine Oil Temp
• MPH
• RPM
• Cylinder Head Temperature
Keep track of your performance by recording maximum/minimum for a variety of parameters including:
• Max Engine Temp
• 0-60 times
• ¼ mile times
• Max RPM
• Max Speed
• Engine Oil Temp
• Transmission Fuel Temp
• Air Intake Temp
Custom Options:
• Customized Shifting
• Adjustable Speed and Rev Limiters
• Speedometer Correction
• WOT Fuel Adjustments
• Adjustable Backlit Color
• Adjustable Idle
KEY FEATURES
• RPM
• MPH
• Engine Oil Temp
• Air Intake Temp
• Manifold Air Flow
• Spark Advance
• Fuel Economy
• Engine Load
• Battery Voltage
• Spark
• Engine Oil Temp
• MPH
• RPM
• Max Engine Temp
• 0-60 times
• ¼ mile times
• Max RPM
• Max Speed
• Engine Oil Temp
• Air Intake Temp
Custom Options:
• Adjustable Idle
