Check connector & wire
i get a code p0340 i believe. its cam position sensor malfunction.
The following is from the Ford 2000 OBD System Operation Summary:
"The ignition system is checked by monitoring three ignition signals during normal vehicle operation:
Profile Ignition Pickup (CKP, commonly known as PIP), the timing reference signal derived from the
crankshaft 36-tooth wheel and processed by the EDIS chip. PIP is a 50% duty cycle, square wave signal
that has a rising edge at 10 deg BTDC.
Camshaft IDentification (CMP, commonly known at CID), a signal derived from the camshaft to identify the
#1 cylinder
Ignition Diagnostic Monitor (IDM), a signal that indicates that the primary side of the coil has fired. This
signal is received as a digital pulse width signal from the EDIS chip. The EDIS chip determines if the
current flow to the ignition coil reaches the required current (typically 5.5 Amps for COP, 3.0 to 4.0 Amps
for DIS) within a specified time period (typically > 200 microseconds for both COP and DIS). The EDIS
chip also outputs status information when the engine is not running.
First, the relationship between successive PIP events is evaluated to determine whether the PIP signal is rational.
Too large a change in 3 successive PIP indicates a missing or noisy PIP signal (P0320). Next, the CMP edge
count is compared to the PIP edge count.
If the proper ratio of CMP events to PIP events is not being maintained
(for example, 1 CMP edge for every 8 PIP edges for an 8-cylinder engine), it indicates a missing or noisy CMP
signal (P0340). Finally, the relationship between IDM edges and PIP edges is evaluated. If there is not an IDM
edge (coil firing) for every PIP edge (commanded spark event), the PCM will look for a pattern of failed IDM events
to determine which ignition coil has failed. If the ignition coil cannot be identified or if the engine is running and
there are no IDM edges, the IDM circuit is malfunctioning (P1351)."
My advice is to check the wire to the CMP sensor for breaks or shorts. Then disconnect and connect the connector a few times to clean it. If that doesn't help, remove the sensor and clean if possible. Then replace the sensor.
