Creager
- October 11, 2004
- Charlotte, NC
- '92 Sport 4x4
As much as I dream about v8 swaps, and the amount research I force myself to do, it’s almost like I can just tell myself, "I kind of know what I'm doing, I should just do it"
That’s simply bad hindsight,
I need something a tad closer to earth for me. Sure, a carbed 289/302 swap would be legal (as of Jan-01-06), and a much more fun/tad Reliable to drive. It would be awesome, but I've looked into the cost of this, not many old trucks with these drivelines kicking around, and the price of getting it up to snuff (rebuilding), it would of ended up spending twice as much as if I just rebuilt the 4.0
I wish to elude myself into the dream 4.0 owners everywhere has fantasized about. The illusion of your truck pulling 75-90mph, just as quick as it can go from 0-20mpg.
That’s where I lead you my friend
I don’t have concrete plan set as of the moment (...ok lets stop for a moment,) the only prior experience I have with any mechanical work is rebuilding/setting up differentials, replacing a transmission, and all the other little jick jacks.- Never once have I torn into a motor
I’ve researched, I know 80% of the parts under the hood by looks alone, and I’m familiar with about 90% of what to expect inside the block
ROOKIESHOOTER has come a long way to exposing me to the idea; I figured it was time to give his private messages a break
I just would like some opinions among the 4.0 crowd... please tell me what you think. My Budget is ended up being around $3000-3500, for the motor build.
The Price Sheet... The final total after the finished build.
$300 - 2x Felpro gasket set
$30 - Ford Lower-intake gasket (metal, over Felpro's cork)
$40 - Felpro-PermaDry Valve-Cover Gaskets
$400 - Stage 2.5 heads/intake; CompCams dual valve *Mildly used
$30 - Felpro head bolts
$200 - 422 Comp cam *Forum classifieds special
$100 - Smithbros 5.525" pushrods
$250 - DeltaCams Rocker arms
$400 - Borla Headers & Y-pipe
$150 - Ford Lifters (new, not rebuilt) (Ebay Special)
$40 - Sealed Power Main Bearings
$30 - Sealed Power Rod Bearings
$25 - Sealed Power Cam Bearings
$180 - Sealed Power SOHC Pistons
$100 - Hastings Moly Rings
$60 - Melling Timing Set
$100 - Melling oil pump and Shaft
$60 - Ford 97TM water pump
~$2645 : Total before machine work
$130 : Heads milled, cleaned, and checked for leaks/cracks.
$20 - Hotbathed upper intake
$500
~$3295 : Total for the engine rebuild
I spend alteast another $1000 on other things, power steering, steering shaft, air conditioning, cooling system... All my prices were rounded, obviously i didnt include sales tax or the extra .99 cents retailers like to add onto the price =P All these prices are accurate within $100 or so.
Some of you guys are probably wondering why I’m putting such a high cam on a truck I do wheel. All they thing I got to say, is the 4.0 is lacking something, no its not the torque and it necessarily isn’t power, its missing a wide array of an RPM range! A cam that allows me to utilize the 4.0 at 5k rpms safely will only complement the 4.56 with 32's. And later down the road the 33's
Well yes, this vehicle is my daily driver, and it looks its going to stay this way for a while. I plan on getting all the large/costly issues taken care off so in the future, I can start focusing more of my time on girls.... err I mean school.
Haha, I guess ill update this threads and pics as I go along
02/04/2006 - Radiator/fan/Compressor shroud is out, Working on AC condenser, didn’t realize I need a bunch of crazy tools.
07/14/2006 - IT RUNS!!!
$500
- Lower intake resurfaced, smoothed out the welds around the upper ports
- Block bored .030"
- Crank Magnafluxed, and polished
- Rotating assembly will be balanced.
- Block bored .030"
