- February 11, 2001
- Red Bluff, Ca
- 1975 Ford Bronco 4x4
Since some of us have pretty tall trucks I thought this would be a useful mod to share.
Since I did the TT/shackles and added 31s it has become more difficult to get into the Explorer since removing the running boards. So I thought I would add a "grab handle" for assistance.
I went to the junkyard and pulled all three stock handles off a Gen 1 Explorer. Now you also must get underneath the headliner and grab the bracket that goes between the handle and the roof structure. So take a 5.5mm socket (deep) for the grab bar bolts, a phillips for the underneath bracket, and a flat screw driver to pry the covers off the handles. I got all three of the handles and brackets for $15... which is an okay deal.
(lost photos)
Next, I pulled the interior apart to access under the headliner. This part just pops off, but I also unbolted the seatbelt shoulder strap and removed the B pillar plastic and rear grab handle and clothes hanger. The further down you can pull the headliner the better. I have a sunroof which probably made this install about 4x easier.
Now you have to bend these tabs up in order for the bracket to sit flush against the roof.
Now the holes for the grab handle are already there. The problem is they have a huuuge diameter hole. I experiemented with a couple things (I'll show you below) but ended up just drilling new 3/16" holes just to the left of the stock holes.
Getting the drill in there was awesome.
New holes drilled.
I used 14 x 7/8" self tapping screws to fasten the bracket.
I then threaded the grab handle bolts into the bracket.
The headliner is even recessed where the handle will go. I don't know why they just didn't add one stock. I imagine this is for RHD Explorer.
I then pushed the headliner up into the bolt heads, making sure it left an indention in the foam. This made for easy drilling for the pilot holes. Just pull the headliner down a little bit and drill 3/16" holes from the top.
Here's the finished product.
Here's the hardware:
Good luck!
(lost photos)
New holes drilled.
Good luck!
