white96x
- September 4, 2002
- Rancho Cuc,Ca(home) SLO,Ca(school)
- 1997 E.B.
alright so i might be jumping the gun on this a little bit but tommorow or tuesday will start the strip down of the front suspension for hopefully the last time...here's the plan: i will continue to run the camburg spindle and uniball upper a-arm suspension however the torsion bars and shocks will be replaced with Radflo 2.0 8" travel remote resivoir coilovers with 600lb eibachs(single rate)....the upper mount will be a box type configuration that is gussetted to the frame(no hoop)....as for the lower, the stock lower arm will be modified gussetted and boxed with new mounting tabs(it's cheaper to do this than build custom lowers and will work just as well) and to top it all off some new urethane lower arm bushings....pics and progress to follow...stay tuned for all you guys looking to ditch your t-bars
a side note, the guy doing the work is the same guy who built jeff's(takinitezx2) long travel kit
