- June 16, 2003
- Humboldt, KS
- 2000 Mounty
and i can't do a thing with it--
it runs, but the idle is a bit high-
Transmission shifts 1-2, but no 3 and up gears-reverse is fine.
Now, I did crawl under and hose the transmission also-and I think there might be an issue there, as the last time I washed down there I got a flashing OD light.
I removed the console and sure enough-where I had a Jet transmission module spliced in earlier was some frayed wiring. I repaired it (I think) and yup, everything was normal.
Now don't give me any jet module crap-I bought it before I knew you guys--
I hope I get in there and find a loose crimp connector from the car wash-but I am afraid I might have wiped out my maf--the high idle worries me.
I looked the pcm, and all connectors over for moisture-and it is dry as a bone.
I'm going to mess with it tomorrow-just thought I'd bring it into tonights conversation for some ideas.
