Ronin8002
- March 23, 2003
- Virginia
- 2008 XLT Ironman
Since our offroad run was cancelled this weekend, I thought it might be a good time to start building some sliders instead
I'll post the design I came up with if I can figure out this google sketchup thing, otherwise I'll just go off my paper drawings and post up pics as I go along.
I don't have a tube bender so I plan on using all square and rectangular tubing...I kind of like the looks of the square tube sliders I've seen pics of anyway so that works out too.
I plan on having a 2"x4" .120 wall rectangular tube right underneath the doors, short side parallel with the ground. I'm going to make 3 frame braces with that same material and use 1/4" plate brackets at the end of those to bolt them onto the frame like Mountaineergreen did. The outer tubes will be 1.5" x 1.5" .120 wall, with 45 degree legs at the front and rear of the slider and 5 other supporting legs in between the outer tube and the rectangular tube.
I like having extra material to work with so I'm planning to buy about 20 feet or so of the 1.5"x1.5" and 24 feet of the 2"x4". My local metal supply tells me that should run around $150. Haven't priced out the 1/4" plate yet for the brackets...probably will get it later on in the project.
Hope to get my metal today or tomorrow and start working on them Saturday...more to come!
