- February 18, 2009
- Winnipeg, Manitoba
- 04 Mustang GT
60 grit is all bad. I've never actually used sand paper before. I don't think you will have great luck getting the old gasket off with sand paper.
If your going to try, use something in the 220 range. If anyone can correct me, or has first hand experience, please chime in. You don't want to take any material off the mating surface while your getting the gasket off.
You can be careful, and use an exacto blade, or the back side of it. Just be careful to use it with an extreme angle so that you don't score the mating surface. I use a blade to get most of the gasket off.
There's not a lot of room in front of the motor to get that water-pump surface cleaned up. I hope the gasket comes off easily for you.
While your cleaning up the blocks head mounting surface, fill the piston holes with rags of some kind to help stop more crud from falling in to the bores. Any of the fine grit that falls in between the piston and cylinder wall that you cant get out will scratch the cylinder bore. that's not good.
