Nctruckman
- February 17, 2012
- NC
- 1994 Explorer XLT 4-Dr
No issues with anything but the shocks. Exhaust has been modified but it's nowhere close to the bar. I just need it to clear the shocks and it'd fit fine. It does have a 2" shackle lift, but that's not why the bar hitsI had slight fitment issues with my 633's trailing arms not lining up with the end link lower flanges. I'm using non stock end links (Moog K80268) because I'm lowered 3 inches in the rear to keep the sway bar's trailing arms parallel with the ground. End link offset appeared to be the same as stock, but are 2-1/2 inches shorter. IIRC, I had to slightly bend the end links to align. Are you having issues with shock or exhaust pipe interference?
Also trying to recall if the OE end links (Motorcraft 80788) were solid or hollow rods. Moog's were solid and could easily be bent. If hollow, bending may not be possible. You may want to contact Addco before attempting to modify your end links. Sway bar itself would be very difficult to adjust correctly without special tools. Keep posted and good luck.
Rear Sway Bar End Link Length
A few small fitment issues, but it's finished. Added 1" of stacked M12 washers and longer grade 8.8 bolts for each side to compensate for the Ranger links smaller offset. The tailpipe is cozied about .25" away from the tailpipe, but doesn't make contact hitting bumps. Torched out the rubber...www.explorerforum.com
Since they use the same bushings, I may just reuse poly bushings I have and get some junkyard links to experiment with, either ranger, explorer or f250. Thank you for the helpSlightly shorter end links (K80139 in bottom pic) may give you enough shock clearance.
Just hate you see you order them to find they won't work. Any issues with the sway bar hitting the pumpkin?
If anything it should put more clearance between the shock and the bar because of the distance being more between the mounting pointsI also had my Addco 633 bar contact my aftermarket shocks when I was using the stock swaybar links. The Moog K80268 (F250) links solved the issue on my 2000 Sport. I pressed in the ES 4.5153 poly bushings for the Explorer without issue and I didn't need to bend anything. Granted this was all done at stock ride height (I ended up gaining more clearance after lowering), hopefully your shackle lift won't throw things off too much.
They're 2" longer ranchos, same diameter as the stock ones and replacements. I may try bending it if I can find a way to do it.Yeah that looks even tighter than mine fit. With stock links, the bar almost touched the shocks at ride height and did touch a little when driving.
With shorter links I had maybe 1/4" clearance:
The lowering blocks helped the most by lifting the bar relative to the shock -- over half an inch of clearance now:
I'm also wondering if your bar was bent too narrow -- I didn't have to modify anything with the links when I installed mine... must've been lucky. Your shocks aren't extra wide or anything, are they?
Not responsible for injury, but I'd hook one end around a tree/fence post and pull the other with a ratchet strap. Use safety chains in case something slips and wear eye protection!I may try bending it if I can find a way to do it.
I'll figure out something if it doesn't work, just so silly it was bent too narrowNot responsible for injury, but I'd hook one end around a tree/fence post and pull the other with a ratchet strap. Use safety chains in case something slips and wear eye protection!
Did you get the Addco front bar too?I'll say this much, It definitely feels like it corners on rails now. No complaints as far as handling
I did not. If it doesnt fit any better than this, I won't be.Did you get the Addco front bar too?
I had no issues with my front bar, other than my tires rubbed after I moved up to 275-wides (that wasn't any fault of the bar though). My Sport corners harder than my Civic now.I did not. If it doesnt fit any better than this, I won't be.
