myf16
- July 22, 2012
- northern California
- 96 Explorer XLT 4WD
I read this article on fuel trim. It seems that long-term fuel trim is a measure of how much adjustment the computer needed to make from its nominal settings to achieve the right result. But the end result should be good as long as the computer is able to adjust and as long as the needed adjustment is not varying rapidly. So I think the smog values should be OK.
However I would like to eliminate some possible causes. I will look again for a vacuum leak and I will change the fuel filter (in case it's clogged) and the wires (150k miles on them) and the plugs (double platinum this time). Then I will cross my fingers and take the smog test.
Edited to add: a clogged fuel filter seems unlikely to produce a high long-term fuel trim at idle and a lower long-term fuel trim at 1500 rpm. In fact, it would be the other way around if the fuel flow is constricted. Spark would normally be stronger at low rpm than at higher rpm. So I'm down to vacuum leak or exhaust leak.
