Deuling
- October 2, 2009
- Muskegon Michigan
- 1986 Ford Bronco2 4x4 xlt
On the frame under the driver side door on my 86 theirs this reservior that has a filter in the bottom and the feed and return fuel lines and some check valves. The 2.9 was runnin crappy and I switched the filter in their, ran good for a while, then crappy again. Took the filter off not clogged, looked up and one of the check valves was laying sideways. I rerouted the lines to bypass this and now it wont run. I connected the feed to the feed and return to the return. im confused. Any thoughts???
