- June 16, 2003
- Humboldt, KS
- 2000 Mounty
I think you may have mistaken what I said. the bolts that came with my WAR 153's are metric/ISO grade 8.8 NOT SAE grade 8 there is a different between the two. ISO 8.8 is comparable to a SAE grade 5 ..... I just wanted to know if people who bought Warriors had swapped the bolts out that came with them.
_______________________________________________________________the above shackles in the pictures are warrior products They are powdercoated in hammertone color and available cheap at www.desertrat.com but youll have to call their number as the part isnt listed on their site
Hey: I have a stock 2000 Explorer Sport 4x4 with a single leaf in the rear. Can I use the WAR-153? And do these come with new bolts and bushings?
If not who sells them with the new bolts and bushings?
Thanks, Man
The only shackles from Desert Rat are for toyota tacomas....will they still work with a 2wd 98 EX Sport
alright i have a question. i just bought some shackles and im prolly going to install them this weekend, if the weather is nice but i remember back in the day when i use to build low rider mini trucks. we use to use blocks and u bolts to lower the truck, now i remember you could also use them to raise the truck, now can u still do that, or is that not a good idea. cause i know they make 3 inch raising/lowering blocks?
just wondering
Blocks will only raise a vehicle if the leaf springs are Over the axle. Since the Explorer has a SUA (spring under axle) setup using blocks will DECREASE Clearance.
how much of a lift do u get
I have a question how hard was it to get the top bolt from the stock shackle especially on the pass side with the tailpipe have been pounding on the damn thing it dosen't want to come out.
Yeah i gave up for tonite ill continue tomorrow hopefully before work. well i thought about grinding the bolt off but didnt want to be left with no car tomorrow if i couldnt get it off Andy can i get that at home depot im guessing its alot better than wd40 cause i almost used a half a can and it didnt do anything..one more question i went to lower the tire cause that would clear alot of room underneath and i couldnt find how to get it down sound stupid i know but where is the screw...thanks
sorry if this is a stupid question but i read through all (well most of this thread but i do not completely understand what to do with the axle. I understand jacking up the truck, but when i take off the bolts, wont the axle drop down? I dont want to damage any shocks or anything so how do i do this? do i put a jack under it and take off the bolts then lower the axle to put the new shackles on? This thread has helped me a lot to understand how to do it. So if anyone could clear up this one question, i will get to working on it tomorrow. How long would it take 2 people to do this? an hour maybe? thanks for yalls help.
